6136 ExecStart=/etc/rc.d/rc.local start (code=exited, status=1/FAI> CPU: 716ms
pomoyka
Сообщение pomoyka » Пн ноя 27, 2023 9:10 am
systemctl status rc-local.service
× rc-local.service - /etc/rc.d/rc.local Compatibility
Loaded: loaded (/usr/lib/systemd/system/rc-local.service; enabled-runtime;>
Active: failed (Result: exit-code) since Mon 2023-11-27 12:00:34 MSK; 6min>
Docs: man:systemd-rc-local-generator(8)
Process: 6136 ExecStart=/etc/rc.d/rc.local start (code=exited, status=1/FAI>
CPU: 716ms
Nov 27 12:00:33 Thisdomen.su rc.local[6356]: umount: /home/thisuser/usr/share/pki>
Nov 27 12:00:33 Thisdomen.su rc.local[6359]: umount: /home/thisuser/usr/share/snm>
Nov 27 12:00:33 Thisdomen.su rc.local[6362]: umount: /home/thisuser/usr/share/ter>
Nov 27 12:00:33 Thisdomen.su rc.local[6365]: umount: /home/thisuser/usr/share/zon>
Nov 27 12:00:33 Thisdomen.su rc.local[6368]: umount: /home/thisuser/usr/share/Geo>
Nov 27 12:00:34 Thisdomen.su rc.local[6371]: umount: /home/thisuser/usr/share/mc:>
Nov 27 12:00:34 Thisdomen.su rc.local[6373]: quotacheck: Cannot find filesystem >
Nov 27 12:00:34 Thisdomen.su systemd[1]: rc-local.service: Control process exite>
Nov 27 12:00:34 Thisdomen.su systemd[1]: rc-local.service: Failed with result 'e>
Nov 27 12:00:34 Thisdomen.su systemd[1]: Failed to start /etc/rc.d/rc.local Comp>
Файлы в папках есть.Как решить? (ALma9.3)
Re: 6136 ExecStart=/etc/rc.d/rc.local start (code=exited, status=1/FAI> CPU: 716ms
Сообщение sbury » Пн ноя 27, 2023 9:41 am
Покажите выводы
 yum list installed quota
cat /etc/rc.d/rc.local
pomoyka
Сообщение pomoyka » Пн ноя 27, 2023 11:11 am
Installed Packages
quota.x86_64 1:4.06-6.el9 @BaseOS
-bash: Repository: command not found
-bash: Installed: command not found
-bash: quota.x86_64: command not found
#!/bin/bash
# THIS FILE IS ADDED FOR COMPATIBILITY PURPOSES
# It is highly advisable to create own systemd services or udev rules
# to run scripts during boot instead of using this file.
# In contrast to previous versions due to parallel execution during boot
# this script will NOT be run after all other services.
# Please note that you must run 'chmod +x /etc/rc.d/rc.local' to ensure
# that this script will be executed during boot.
touch /var/lock/subsys/local
sleep 15
umount -l /home/User1/var/run/mysqld
umount -f /home/User1/var/run/mysqld
mount --bind /var/run/mysqld /home/User1/var/run/mysqld
umount -l /home/User1/usr/bin/php52
umount -f /home/User1/usr/bin/php52
mount --bind /usr/jail_skeleton/usr/bin/php52 /home/User1/usr/bin/php52
umount -l /home/User1/usr/bin/php53
umount -f /home/User1/usr/bin/php53
mount --bind /usr/jail_skeleton/usr/bin/php53 /home/User1/usr/bin/php53
umount -l /home/User1/usr/bin/php54
umount -f /home/User1/usr/bin/php54
mount --bind /usr/jail_skeleton/usr/bin/php54 /home/User1/usr/bin/php54
umount -l /home/User1/usr/bin/php55
umount -f /home/User1/usr/bin/php55
mount --bind /usr/jail_skeleton/usr/bin/php55 /home/User1/usr/bin/php55
umount -l /home/User1/usr/bin/php56
umount -f /home/User1/usr/bin/php56
mount --bind /usr/jail_skeleton/usr/bin/php56 /home/User1/usr/bin/php56
umount -l /home/User1/usr/bin/php70
umount -f /home/User1/usr/bin/php70
mount --bind /usr/jail_skeleton/usr/bin/php70 /home/User1/usr/bin/php70
umount -l /home/User1/usr/bin/php71
umount -f /home/User1/usr/bin/php71
mount --bind /usr/jail_skeleton/usr/bin/php71 /home/User1/usr/bin/php71
umount -l /home/User1/usr/bin/php72
umount -f /home/User1/usr/bin/php72
mount --bind /usr/jail_skeleton/usr/bin/php72 /home/User1/usr/bin/php72
umount -l /home/User1/usr/bin/php73
umount -f /home/User1/usr/bin/php73
mount --bind /usr/jail_skeleton/usr/bin/php73 /home/User1/usr/bin/php73
umount -l /home/User1/usr/bin/php74
umount -f /home/User1/usr/bin/php74
mount --bind /usr/jail_skeleton/usr/bin/php74 /home/User1/usr/bin/php74
umount -l /home/User1/usr/bin/php80
umount -f /home/User1/usr/bin/php80
mount --bind /usr/jail_skeleton/usr/bin/php80 /home/User1/usr/bin/php80
umount -l /home/User1/usr/bin/php81
umount -f /home/User1/usr/bin/php81
mount --bind /usr/jail_skeleton/usr/bin/php81 /home/User1/usr/bin/php81
umount -l /home/User1/usr/bin/php82
umount -f /home/User1/usr/bin/php82
mount --bind /usr/jail_skeleton/usr/bin/php82 /home/User1/usr/bin/php82
umount -l /home/User1/usr/lib64
pomoyka
mount --bind /usr/jail_skeleton/usr/bin/php55 /home/User2/usr/bin/php55
umount -l /home/User2/usr/bin/php56
umount -f /home/User2/usr/bin/php56
mount --bind /usr/jail_skeleton/usr/bin/php56 /home/User2/usr/bin/php56
umount -l /home/User2/usr/bin/php70
umount -f /home/User2/usr/bin/php70
mount --bind /usr/jail_skeleton/usr/bin/php70 /home/User2/usr/bin/php70
umount -l /home/User2/usr/bin/php71
umount -f /home/User2/usr/bin/php71
mount --bind /usr/jail_skeleton/usr/bin/php71 /home/User2/usr/bin/php71
umount -l /home/User2/usr/bin/php72
umount -f /home/User2/usr/bin/php72
mount --bind /usr/jail_skeleton/usr/bin/php72 /home/User2/usr/bin/php72
umount -l /home/User2/usr/bin/php73
umount -f /home/User2/usr/bin/php73
mount --bind /usr/jail_skeleton/usr/bin/php73 /home/User2/usr/bin/php73
umount -l /home/User2/usr/bin/php74
umount -f /home/User2/usr/bin/php74
mount --bind /usr/jail_skeleton/usr/bin/php74 /home/User2/usr/bin/php74
umount -l /home/User2/usr/bin/php80
umount -f /home/User2/usr/bin/php80
mount --bind /usr/jail_skeleton/usr/bin/php80 /home/User2/usr/bin/php80
umount -l /home/User2/usr/bin/php81
umount -f /home/User2/usr/bin/php81
mount --bind /usr/jail_skeleton/usr/bin/php81 /home/User2/usr/bin/php81
umount -l /home/User2/usr/bin/php82
umount -f /home/User2/usr/bin/php82
mount --bind /usr/jail_skeleton/usr/bin/php82 /home/User2/usr/bin/php82
umount -l /home/User2/usr/lib64
umount -f /home/User2/usr/lib64
mount --bind /usr/jail_skeleton/usr/lib64 /home/User2/usr/lib64
mount --bind /usr/jail_skeleton/usr/lib /home/User2/usr/lib
umount -l /home/User2/usr/share/fontconfig
umount -f /home/User2/usr/share/fontconfig
mount --bind /usr/jail_skeleton/usr/share/fontconfig /home/User2/usr/share/fontconfig
umount -l /home/User2/usr/share/fonts
umount -f /home/User2/usr/share/fonts
mount --bind /usr/jail_skeleton/usr/share/fonts /home/User2/usr/share/fonts
umount -l /home/User2/usr/share/i18n
umount -f /home/User2/usr/share/i18n
mount --bind /usr/jail_skeleton/usr/share/i18n /home/User2/usr/share/i18n
umount -l /home/User2/usr/share/locale
umount -f /home/User2/usr/share/locale
mount --bind /usr/jail_skeleton/usr/share/locale /home/User2/usr/share/locale
umount -l /home/User2/usr/share/pki
umount -f /home/User2/usr/share/pki
mount --bind /usr/jail_skeleton/usr/share/pki /home/User2/usr/share/pki
umount -l /home/User2/usr/share/snmp
umount -f /home/User2/usr/share/snmp
mount --bind /usr/jail_skeleton/usr/share/snmp /home/User2/usr/share/snmp
pomoyka
Сообщение pomoyka » Пн ноя 27, 2023 11:12 am
umount -l /home/User2/usr/share/terminfo
umount -f /home/User2/usr/share/terminfo
mount --bind /usr/jail_skeleton/usr/share/terminfo /home/User2/usr/share/terminfo
umount -l /home/User2/usr/share/zoneinfo
umount -f /home/User2/usr/share/zoneinfo
mount --bind /usr/jail_skeleton/usr/share/zoneinfo /home/User2/usr/share/zoneinfo
umount -l /home/User2/usr/share/GeoIP
umount -f /home/User2/usr/share/GeoIP
mount --bind /usr/jail_skeleton/usr/share/GeoIP /home/User2/usr/share/GeoIP
umount -l /home/User2/usr/share/mc
umount -f /home/User2/usr/share/mc
mount --bind /usr/jail_skeleton/usr/share/mc /home/User2/usr/share/mc
umount -l /home/User3/var/run/mysqld
umount -f /home/User3/var/run/mysqld
mount --bind /var/run/mysqld /home/User3/var/run/mysqld
umount -l /home/User3/usr/bin/php52
umount -f /home/User3/usr/bin/php52
mount --bind /usr/jail_skeleton/usr/bin/php52 /home/User3/usr/bin/php52
umount -l /home/User3/usr/bin/php53
umount -f /home/User3/usr/bin/php53
mount --bind /usr/jail_skeleton/usr/bin/php53 /home/User3/usr/bin/php53
umount -l /home/User3/usr/bin/php54
umount -f /home/User3/usr/bin/php54
mount --bind /usr/jail_skeleton/usr/bin/php54 /home/User3/usr/bin/php54
umount -l /home/User3/usr/bin/php55
umount -f /home/User3/usr/bin/php55
mount --bind /usr/jail_skeleton/usr/bin/php55 /home/User3/usr/bin/php55
umount -l /home/User3/usr/bin/php56
umount -f /home/User3/usr/bin/php56
mount --bind /usr/jail_skeleton/usr/bin/php56 /home/User3/usr/bin/php56
umount -l /home/User3/usr/bin/php70
umount -f /home/User3/usr/bin/php70
mount --bind /usr/jail_skeleton/usr/bin/php70 /home/User3/usr/bin/php70
umount -l /home/User3/usr/bin/php71
umount -f /home/User3/usr/bin/php71
mount --bind /usr/jail_skeleton/usr/bin/php71 /home/User3/usr/bin/php71
umount -l /home/User3/usr/bin/php72
umount -f /home/User3/usr/bin/php72
mount --bind /usr/jail_skeleton/usr/bin/php72 /home/User3/usr/bin/php72
umount -l /home/User3/usr/bin/php73
umount -f /home/User3/usr/bin/php73
mount --bind /usr/jail_skeleton/usr/bin/php73 /home/User3/usr/bin/php73
umount -l /home/User3/usr/bin/php74
umount -f /home/User3/usr/bin/php74
mount --bind /usr/jail_skeleton/usr/bin/php74 /home/User3/usr/bin/php74
umount -l /home/User3/usr/bin/php80
umount -f /home/User3/usr/bin/php80
mount --bind /usr/jail_skeleton/usr/bin/php80 /home/User3/usr/bin/php80
umount -l /home/User3/usr/bin/php81
umount -f /home/User3/usr/bin/php81
mount --bind /usr/jail_skeleton/usr/bin/php81 /home/User3/usr/bin/php81
umount -l /home/User3/usr/bin/php82
umount -f /home/User3/usr/bin/php82
mount --bind /usr/jail_skeleton/usr/bin/php82 /home/User3/usr/bin/php82
umount -l /home/User3/usr/lib64
umount -f /home/User3/usr/lib64
mount --bind /usr/jail_skeleton/usr/lib64 /home/User3/usr/lib64
mount --bind /usr/jail_skeleton/usr/lib /home/User3/usr/lib
umount -l /home/User3/usr/share/fontconfig
umount -f /home/User3/usr/share/fontconfig
mount --bind /usr/jail_skeleton/usr/share/fontconfig /home/User3/usr/share/fontconfig
umount -l /home/User3/usr/share/fonts
umount -f /home/User3/usr/share/fonts
mount --bind /usr/jail_skeleton/usr/share/fonts /home/User3/usr/share/fonts
umount -l /home/User3/usr/share/i18n
umount -f /home/User3/usr/share/i18n
mount --bind /usr/jail_skeleton/usr/share/i18n /home/User3/usr/share/i18n
umount -l /home/User3/usr/share/locale
umount -f /home/User3/usr/share/locale
mount --bind /usr/jail_skeleton/usr/share/locale /home/User3/usr/share/locale
umount -l /home/User3/usr/share/pki
umount -f /home/User3/usr/share/pki
mount --bind /usr/jail_skeleton/usr/share/pki /home/User3/usr/share/pki
umount -l /home/User3/usr/share/snmp
umount -f /home/User3/usr/share/snmp
mount --bind /usr/jail_skeleton/usr/share/snmp /home/User3/usr/share/snmp
umount -l /home/User3/usr/share/terminfo
umount -f /home/User3/usr/share/terminfo
mount --bind /usr/jail_skeleton/usr/share/terminfo /home/User3/usr/share/terminfo
umount -l /home/User3/usr/share/zoneinfo
umount -f /home/User3/usr/share/zoneinfo
mount --bind /usr/jail_skeleton/usr/share/zoneinfo /home/User3/usr/share/zoneinfo
umount -l /home/User3/usr/share/GeoIP
umount -f /home/User3/usr/share/GeoIP
mount --bind /usr/jail_skeleton/usr/share/GeoIP /home/User3/usr/share/GeoIP
umount -l /home/User3/usr/share/mc
umount -f /home/User3/usr/share/mc
mount --bind /usr/jail_skeleton/usr/share/mc /home/User3/usr/share/mc
quotacheck -avugmf
txt не смог прикрепить
Сообщение sbury » Пн ноя 27, 2023 12:41 pm
 rpm -ql quota | grep sbin
и этого быть не должно. Похоже на какуюто обрезанную ошибку. Покажите ее скрином
pomoyka
Сообщение pomoyka » Пн ноя 27, 2023 1:36 pm
ок.Готово
Сообщение sbury » Пн ноя 27, 2023 1:49 pm
Вывод А этого что уже нет?
и еще вывод
cat /lib/systemd/system/rc-local.service
ls -l /etc/rc.d/rc.local
pomoyka
Сообщение pomoyka » Пн ноя 27, 2023 2:36 pm
Уже нету, причина не известна.
Сообщение sbury » Пн ноя 27, 2023 3:10 pm
попробуйте закоментить в rc.local строки с quotacheck и перезапустить сервис.
