/etc/nginx/vhost_logs Ротация логов
Логи по 200 мб. Есть очучение, что ротация логов в этой папке не работает.
Хотя все прописано, вроде бы...
/var/log/nginx/*log {
create 0644 nginx nginx
daily
rotate 10
missingok
notifempty
compress
sharedscripts
postrotate
/bin/kill -USR1 `cat /run/nginx.pid 2>/dev/null` 2>/dev/null || true
endscript
/etc/nginx/vhost_logs/* {
create 0644 root nginx
daily
rotate 10
size 40M
missingok
notifempty
compress
sharedscripts
postrotate
endscript
daily
rotate 10
missingok
notifempty
compress
sharedscripts
postrotate
endscript
daily
rotate 10
size 40M
missingok
notifempty
compress
sharedscripts
postrotate
endscript
Re: /etc/nginx/vhost_logs Ротация логов
Я на своем сервере не вижу проблем, какая ос?
1 сервер
- Безымянный-2.jpg (224.71 КБ) 40139 просмотров
Покажите выводы
systemctl status logrotate
systemctl restart logrotate
rpm -qa | grep logrotate
× logrotate.service - Rotate log files
Loaded: loaded (;;file://blackrussian.su/usr/lib/systemd/system/logrotate.service/usr/lib/systemd/system/logrotate.service;;; static)
Active: failed (Result: exit-code) since Thu 2024-06-13 00:00:02 MSK; 14h ago
TriggeredBy: ● logrotate.timer
Docs: ;;man:logrotate(8)man:logrotate(8);;
;;man:logrotate.conf(5)man:logrotate.conf(5);;
Main PID: 425732 (code=exited, status=1/FAILURE)
CPU: 236ms
Jun 13 00:00:01 blackrussian.su systemd[1]: Starting Rotate log files...
Jun 13 00:00:01 blackrussian.su logrotate[425742]: Redirecting to /bin/systemctl restart rsyslog.service
Jun 13 00:00:01 blackrussian.su logrotate[425754]: Redirecting to /bin/systemctl restart rsyslog.service
Jun 13 00:00:02 blackrussian.su logrotate[425732]: error: failed to rename /etc/nginx/vhost_logs/mysite.ru_access to /etc/nginx/vhost_logs/site>
Jun 13 00:00:02 blackrussian.su logrotate[425829]: Redirecting to /bin/systemctl restart rsyslog.service
Jun 13 00:00:02 blackrussian.su systemd[1]: logrotate.service: Main process exited, code=exited, status=1/FAILURE
Jun 13 00:00:02 blackrussian.su systemd[1]: logrotate.service: Failed with result 'exit-code'.
Jun 13 00:00:02 blackrussian.su systemd[1]: Failed to start Rotate log files.
Job for logrotate.service failed because the control process exited with error code.
See "systemctl status logrotate.service" and "journalctl -xeu logrotate.service" for details.
logrotate-3.18.0-9.brainy.el9.x86_64
upd
2-ой сервер на almalinux 9,3 - картина та же
systemctl stop logrotate
yum update logrotate
systemctl restart logrotateRe: /etc/nginx/vhost_logs Ротация логов
Все взлетело.Будем посмотреть как дальше будет работать.
СПАСИБО!
СПАСИБО!
приветствую. та же проблема, почти. Почему то логротате говорит что система в реад онли, хотя спокойно работаю с ФС, файлы создаю, чистил в ручную... логи пишутся...
apt install logrotate
Reading package lists... Done
Building dependency tree
logrotate is already the newest version (3.14.0-4ubuntu3)
запустив в ручную
logrotate -vf /etc/logrotate.conf
логи крутануло
предполагаю что проблема в настройках сервиса
в строках
ProtectSystem=full
RestrictRealtime=true
запустив в ручную
логи крутануло
в строках
ProtectSystem=full
Покажите саму ошибку полностью которую выдает logrotate.
